I’m not good in english (i’m french) so, excuse me and thanks in advance…
I bought 2 weeks ago, a dac : audiophonics.fr/fr/dac-diy/a … 10295.html for my raspberry pi 2. I installed vlumio and it worked with a other dac but not with this one. The RPI recognized it (aplay command) but there is no sound…
nothing wrong with your english
I would connect the GND pin (next to MCLK) to a GND pin on the PI Pin header as well.
Perhaps the analog circuit does work otherwise.
Did you choose the correct I2S driver?
Well, for one: the pin is not there because the designer thought two times GND is better than one
Obviously this is related to different circuits on the board, people at Audiophonics (Teradak?) could probably tell you more.
