Have loaded 0.861 img & entered nas in my music/add new drive it gives a false reading of size 13mb actual size 1.5tb of music & it does not load the library when I navigate the Nas in music library it is blank Rpi 2 had no issue like this & worked well Any clues??
If you have ssh access to your RPi, then check your /var/log/volumio.log for mounting/access errors.
Ok thanks for taking the time to read … not got ssh but going to look it up see if I can get to grips with it
