Im trying to get my newly installed Volumio to do spotify connect but i seem to run in to all kinds of problems.
- Installing Spotify Plugin seems to work but it wont being enabled. Giving this message:
spop Plugin
This plugin is failing to start. Please install updated version, or contact plugin developer
- Volumio Spotify Connect2 plugin wont install (but gets installed…isch)…
The installation stalls at 70%
Then says: Plugin installation script failed!! An error occurred while installing the plugin Error
- Both plugins can be seen in the “installed plugins” list
3.1 The Spotify-plugin cant be enabled, see first issue.
3.2 Volumio Spotify Connect2 can be enabled, but doesnt work.
When i try to update the Spotify connect settings i get this:
Spotify Connect
Unable to update config: Error: Command failed: /usr/bin/sudo /bin/systemctl restart volspotconnect2.service Failed to restart volspotconnect2.service: Unit volspotconnect2.service not found.
I’ve tried reinstall the whole system, reboot etc.
