Volumio Information
Volumio Version:
Hardware: Rai 4
DAC: Allo Boss 2.873
There is no Boss 2 in the DAC list, how to proceed? Thanks
Volumio Version:
Hardware: Rai 4
hello and welcome to the forum
do you mean allo boss 1.2 or in other words the second version of allo boss.
if so then you can just select allo boss under i2s.
this one.
https://allo.com/sparky/boss-dac.html
A good idea might be to edit the original post with the correct information to avoid confusion?
Edit: did you try Allo Boss under i2s anyway?
Yes, no sound.
I see that the Boss 2 player uses a totally different DAC (Cirrus Logic CS43198), so you will need to get hold of the appropriate overlay file (if not already there). From the Boss 2 Player user manual (you do have a copy? ;), you can see:
Yes, thanks, not sure how to proceed. Not familiar with codes, looking for a step by step guide.
