Hi All,
I was hoping volumio 3.832 would work on this set up, but I can’t get any output on the configured Digi Pro, nor detection of the SSD with the music library.
Are there some diagnostics to help find out what is going wrong?
I was expecting to have to load more packages after installing the image. Have I missed something?
And a separate question… Is Spotify connect supported?
Sorry for the noob questions!
Hi @Mutineering ,
Welcome to Volumio!
Regarding your questions:
Diagnostics
Please follow this guide to generate a log link:
How to send a log link for a bug report?
Once you have the URL, share it here—it might give us insight into what’s going on.
SSD Detection
Volumio should recognize most USB-attached storage automatically. A few things to check:
- How is the drive formatted?
- Does it spin up or show signs of life?
- The Raspberry Pi 3 might not supply enough power for some SSDs—using a powered USB hub can help.
Many thanks! I rebooted an re-ran the setup wizard and got some nice audio output! I also found and installed the Spotify plugin. Just need to find that SSD now…
Perhaps it’s just a power supply issue to the suptronics SSD shield that houses the SSD. I’ll check it’s not dropping voltage. Hmm… How do I log into this volumio beastie to do an ‘lsusb’ I wonder?
