Hi, i have some issue to make this config works
Raspberry RPI3
ALLO - PIANO Hi-Fi DAC (i’ve changed the switcher for RPI compatibilty “on”)
ALLO - Kali i2s Reclocker
what should i put inside “playback option” ?
I’ve tried “Piano DAC” but got the message “failed to output audio”
many thanks !
volumio
2
Please use RaspyDACV3, let me know
PS: The driver for allo is being worked out as we speak, on which Volumio version are you?
Ok thanks, i’ll try tonight
yes, very last version, installed it 3 days ago
working fine with RaspyDACV3
not with Allo DAC or Allo 2.1
Many thanks
great sound !
