trying to update to 2.118 with WebGUI destroyed my well working Volumio2 with HifiBerry DAC+. After creating a new SDCard with Volumio in Vers. 2.118 i’ve got no sound from HifiBerry. Is there a solution for my problem?
thx, fal
In the playback options, try to turn off/on I2S DAC, then select Hifiberry DAC Plus in Output Device and DAC Model, save, and restart it.
Sent from my SM-G610F using Tapatalk
thx, i’ll try later
fal
Hi to all,
i found a solution:
-> In the playback options, try to turn off/on I2S DAC, then select Hifiberry DAC Plus in Output Device and DAC Model, save, and restart it.
thats not possible! by turning off I2S onli Hifiberry DAC or Audio jack is possible. So i choosed Hifiberry and restart the pi. When the pi is up again, choosed Hifiberry DAC +, I2S ON, Hifiberry DAC +, than restart.
Now it works. Maybe that is a solution also for other…
Fal
