I am quite new to RP + Volumio.
But I have installed all parts and all is working well so far:
RP4
7" original Touchscreen
Volumio (incl. Touch-Plugin)
Maybe I have overlooked those, but I did not find any settings for controlling the “screen off” function or even to avoid that the Touchscreen is going off after some time…
I don´t want to touch the screen each time to I just want that the Touchscreen is always ON…!
My simple question is:
Is there any setting to manage this Touchscreen on/off or screen time inside Volumio or maybe in RP4 ?
in the settings>> plugins>>installed plugins>> touch plugin
you will find the settings click on this here you will find screensaver time out :
instead of the 120 sec you replace it with 0
OMG Yes that is so easy…I didn’t look at installed plugins because I thought the plugins were only listed there, but I had no idea that you could then make settings there
