Try to connect a Tinkerboard (don’t matter, could be a Raspi either) with Volumio via USB with my Amplifer ROTEL RA-1592 but don’t know which setting to choose. Any hints?
Micha
Micha
Hi Micha,
go to settings -> playback options -> audio output -> select USB (you should see the name of the ROTEL audio device). Click save. done
Unfortunately there is no USB in the List … Problem of the tinkerboard build?
In the Raspberry Pi-Build -> No Problem!
Can you tel me: I’ve got a Allo DigiOne-Board and the USB-Connection, the Rotel Amplifer serves both … what is more audiophil?
