For my first Raspberry Pi Project, i Installed today Volumio on my Raspberry Pi 3.
VERSION: 0.976
RELEASE DATE: 28-07-2016
The access over SSH (with Putty) with username:volumio works fine.
But with the root user i always get “Access denied”.
No changes have yet been made on the System.
The Board Search has not helped me.
Thx & Greetings from Germany
PeX
Ok, I find it.
In the sshd_config
was
permitrootlogin no
I change it to
permitrootlogin yes
and
service ssh restart
now it Works
But good to know, that its default on no.
cheers
just to know, why do you need a root access ? Using SUDO should be enough. Or can you explain ?
I dont need it directly.
But i use a Tutorial to install the Spotify Connect into Volumio. In this Tutorial, there use/need the root User to Copy the files via WinSCP in the folder.
I 've got a suggestion for you, I started to write a plugin for Spotify connect, you can test it here: https://github.com/balbuze/volumio-plugins/tree/master/plugins/music_service/volspotconnect. You need a app key. Download the zip file and install it through the UI. Let me know…
edit : installation is a bit long and you have to be select English as language to access settings. And it may NOT work…
Hey Thx. I will check it
At this time i used a Tutorial from the German Page PowerPi.
powerpi.de/spotify-connect-auf-d … bedienung/
After first Test it looks good. But i think i need the HiFiBerry for a better sound.
Instead of allowing root login via the network, best practice would be to just have you login as volumio and run:
sudo su
to become root and keep a session open as the root user.
or:
sudo -i
will give you the same result.
