It is quite similar. Roon Bridge as a volumio plugin does use a different path for storing its setting files than standard installations of Roon Bridge (in the /data/configuration directory).
But aside from that it simply makes the installation easier for users who are not familiar with ssh or shell.
Technically this is be possible.
But it requires more effort (and time). It can be retrieved by the Roon API. But I thought, it is more useful if people could already install it and use it without metadata display instead of waiting for a full featured implementation.
Hi, Chris
I think I am trying using your roon bridge plug in in my BBB with volumio 2.
It is a on the list download.
But it seem it fail to run and cannot uninstall as well.
Any update for this or solution?
Note: BBB is unsupported, we have no idea how this version was built.
There is no maintainer, except @Mullet who is doing is upmost to help people by running the BBB build as a service (which is very much appreciated).
But there is nobody else to ask for technical support.
Very happy with both Volumio and over the last 2 days also Roon and Roon Bridge plugin in volumio. It plays all music from my NAS as well as Tidal.
However one thing doesn’t work as I would like - when I play music from the Roon app I don’ see it in neither volumio web UI nor on the attached LCD display.
Is there any way how to show album art and music info in volumio web ui and attached LCD while playing music from Roon app (via Roon Bridge p,ugin and Volumio end point)?
Hello.
roon is on a separate pc, volumio takes a signal from roon and releases it to usb for usb. the music plays and doesn’t stutter. but the volumio as if it bypassed this signal because the progress bar or, for example, the title of the author or the song does not work. below I put the signal path from the roon.please help me
I tried uninstalling then reinstalling the plug-in, but unstall gives this error:
"An error occurred while uninstalling the plugin: Error: Command failed: /usr/bin/sudo /bin/systemctl stop roonbridge.service Failed to stop roonbridge.service: Unit roonbridge.service not loaded.”
So the Roon service is not running. Volumio Primo.
Maybe someone can help.
