Roon Bridge Plugin uninstall failed
evironment
Volumio Audiophile Music Player for PC (X86/X64)
VERSION: 2.729
RELEASE DATE: 18-03-2020
I install roon bridge from volumio plugin list, however the installation stopped sue to lost internet connection. Then I click into installed plugins, I can see that roon brige is installed but not activated. BUT can not uninstall:
An error occurred while uninstalling the plugin: Error: Command failed: /usr/bin/sudo /bin/systemctl stop roonbridge.service Failed to stop roonbridge.service: Unit roonbridge.service not loaded.
Would Volumio service be so kind to help solve this problem ?
Not sure. I am in China and don’t have good connection to ROON official servers. This is the problem making headache.
Enable volumio ssh access.
$ curl -O http://download.roonlabs.com/builds/roonserver-installer-linuxx86.sh
$ nano ./roonbridge-installer-linuxx86.sh
Change the PACKAGE_URL= line to the following because Roon official link removed x86 package.
PACKAGE_URL=http://roon-updates-stable.s3.amazonaws.com/RoonBridge_linuxx86.tar.bz2
$ chmod +x roonserver-installer-linuxx86.sh
$ sudo ./roonserver-installer-linuxx86.sh
Reboot. Enjoy!
I have a similar problem. I tried to uninstall the official Roon Bridge plugin, but the removal failed because of some folder permission error that I failed to capture.
Now the plugin is in some weird state, where it can’t be enabled or removed. How do I uninstall? I tried the instructions above, but the link to the first required file doesn’t exist anymore.
How can I manually remove an official plugin?
