RME AIO PCIe soundcard
x86 install
Internal card only plays one channel even though other channels are selected and saved in mixer settings.
Fix is to ssh into volumio and run alsamixer (select the card) where it is found that only the first channel is active.
Increase volume for second channel.
ssh another instance while the alsamixer window is open and in the new window run ‘sudo alsactl store’
Reboot and now both channels play.
The UI volume control for the card still, irritatingly, only controls one channel.
There is obviously a bug in the UI>alsa communications.
If there is a fix for the volume control to work with both channels then I can bypass my preamp and run the output from the RME card and Volumio direct to the power amplifiers.
Can supply a diagnostic if needed.
Many thanks for viewing.
OS info
Version of Volumio: 3.435
Hostname: rme
Kernel: 5.10.165-volumio
Governor: performance
Uptime: 0 days, 3 Hrs, 59 Minutes, 3 Seconds
Audio info
Hw audio configured: RME AIO_c2eeaa
Mixer type: Hardware
Number of channels: 16
Board info
Manufacturer: Hewlett-Packard
Model: HP t610 PLUS WW Thin Client
Version:
Firmware Version: -
CPU info
Brand: G-T56N Processor
Speed: 1.65Ghz
Number of cores: 2
Physical cores: 2
Average load: 4%
Temperature: °C
Memory info
Memory: 3973252 Ko
Free: 2329096 Ko
Used: 1644156 Ko
Storage info
INTERNAL storage - Size: 3809Mo
Used: 76Mo
Available for storage: 3533Mo (93%)
