maybe a newbie question:
I just installed my ADI-2 DAC via USB and according to compatibility list, it is supported by Volumio and Hardware Mixer is also supported.
In the settings, I changed the Mixer to “Hardware”, but Volume change in Volumio has no effect.
I also tried all possible types of mixer like AES Rate, System Rate, etc, but also no effect.
What a am I missing? Or is it not possible to control the volume via Volumio with this DAC?
When plugging the ADI-2 into my Windows 11 Notebook, Volume Control via Software is possible.
So generally it seems to work, but not in combination with Volumio.
Any things I might be missing to make it also work with Volumio?
Yes, I understand. But I have a DAC with a supposed HW volume, but with no effect when volume is changed. So only software volume control is effective in this case.
But don’t know for your dAc…
Again, if this is not implemented, your only choise is software volume control, which Windows would make use of.
Check with RME, I have multiple USB DACs, only one of them does hw volume control after an xmos firmware update.
Thanks a lot for the Link.
The Text says, that HW Volume Control is not available for any OS. This seems not to be the actual Status, as it works with Windows OS. Still hoping for a kind of tweak to make it also work with Linux/Volumio. Otherwise I will arrange myself with SW Volume Control
It also depends on what you are playing. Volumio cannot change the volume of DSD music unless the DSD is converted to PCM. It is possible that Windows is doing that conversion. The ADi-2 DAC (I have an ADI-2 Pro) allows you to play DoP or native DSD. Neither of those modes can have the volume controlled by the sender. The volume of PCM can be controlled by the sender.
Personally, I want the music to be as accurate as possible, which is why I use DSD256 most of the time. My ADI-2 Pro has a volume control, but I leave that, and feed the analog music through a Spectral pre-amp or directly into my Koss electrostatic headphones, both of which have volume controls. There is no computer in my setup after Volumio, and I would never use software volume control there, as it would require conversion to PCM.
Basically it provides a C daemon that controls the volume of RME DACs from the ADI 2 family through the MIDI protocol (you have to have the DAC attached via USB).
Personally I prefer a lighter alternative: I have a set of scripts that I can trigger via volumito or SSH that increase/decrease the volume of my RME ADI 2/4 PRO SE DAC, and I do not care about the UI showing the volume as 100/100 all the time.
