Rivo+ wrong output in roon
i don`t know if it is a matter of Volumio or Roon.
I`m using a Rivo+ as a RoonReady device. The DAC is connected with AES/EBU connection, but roon recognizes it as USB-output. Is there something wrong with roon ready?
If i connect my “old” Rivo in the same way, roon recognizes the digital output. In addition i can not play DSD64 with the Rivo+, but with the “old” Rivo i can do that without problems, when i use the same device connection.
Any suggestions?
Thanks for help.
