Rivo - Problems in updating the library on the micro-SD card
Good morning,
I have the following problem almost every time I update the library stored in a micro-SD card connected to the Rivo.
Once new files are copied on the card, the functions ‘Update’ and ‘Rescan’ seem not to work, clicking on the them nothing happens. Only after several restart of the Rivo or even formatting the SD card e re-coping the entire library, the system works. This is rather annoying and cannot be an acceptable solution.
The issue happens regardless the way the SD is updated - directly accessing the card via //[Rivo name] from a laptop or disconnecting the card from the Rivo and connecting it to the laptop.
Any help is welcome.
Thanks and kind regards - roberto
Hi Roberto,
can you share a log after you try to update the database? Paste the link here, we’ll have a look
Hi Michelangelo,
thanks for replying - Below the link to the log when the issue happened the first time.
http://logs.volumio.org/rivo/O2jcmfP.html
roberto
Hi Roberto,
I kindly suggest to reply to our ticket for support. Please let’s continue our conversation there.
Best,
Volumio support
