Rivo Plus wont boot
I’m having problems with my Rivo Plus, which is only a few days old. It no longer boots. The red LED on the power button is very dimly lit. When I press the button, nothing happens. You can see a blue light shining through at the edges of the front panel.
What can I do? The problem occurs with the Lineo 5 as well as with the included switching power supply …
Hello, did you already make a support ticket? You get free support with a Rivo. Open a ticket here.
the problem is solved already …
How was the problem solved? It’s the same with me.
It seems to be a loose connection at the power jack. It’s working now, so I’ll leave it on.
But I am facing the issue till now. Have you any idea to resolve. Thanks in advance
You have free support for the Rivo, create a support ticket here.
