Does anyone have the brand list available in the Playback Option Menu of the Rivo Plus?
I want to know if there is compatibility with dac Holo Audio Cyan 2 before buying it.
Thanks!
The best possible response!
Thanks Darmur!
Hi I own a holo audio Cyan 2 DAC and a Rivo Plus. With the new Firmware Update you can choose via a drop list the config for the Holo audio Cyan 2 DAC. Sounds great, but i can’ t say its better or worse than the USB connection.
And did you compare both to the coaxial?
Not yet but the I2s sounds great. I use a shanling audio cable, not a HD HDMI video cable.
Hi, and Happy New Year everyone!
I have a Cayin iDAC-8 and would like to buy Rivo+ streamer to use i2s input. Would anyone know whether the i2s pinout settings of the Rivo+ are compatible with the Cayin iDAC-8 pinouts?
Where can i find a list of compatible i2s capable dacs that can be used with the Rivo+?
Thanks and Cheers!
Scusate, ho intenzione di acquistare Volumio Rivo+ ma vorrei essere sicuro che può essere collegato al DAC LAIV Harmony uDac (micro) via I2S. Potete aiutarmi ? Grazie
Please post in English. There are lots of handy tools available, and while our community is helpful, we can’t expect everyone to double as a translator.
Thanks!
Yes it is definitely possible, please have a look to the following video where the Rivo Plus and LAIV uDAC are reviewed together, with both USB and I2S connections
Please also have a look here:
thanks
