Rivo ignores AES/EBU Output
i noticed a strange behaviour with my Rivo. My Rivo is connected with AES/EBU to my DAC. But since the update to version 3.886, only SPDIF is shown and selectable as output device.
Before that SPDIF/AES/EBU was shown as output device options.
Now Roon did not accept DSD64 upsampling, which was no problem before.
Any suggestions?
Thanks!
As a Rivo owner, you’re entitled to premium support with exclusive access to knowledge bases unavailable to the community.
As far as I am aware if S/PDIF is active, AES/EBU must be active as well
Please raise a support ticket here:
https://volumio.atlassian.net/servicedesk/customer/portal/1/group/1/create/1
Hello Wheaten,
thank you. I opened a support ticket.
For your information:
Yes, the AES/EBU is active.
I use the rivo as a roon ready device and now roon displays the in the signal path the rivo as an analog output instead of digital, as it was before the update to version 3.886.
So upsampling to DSD64 is not possible anymore, even it if worked fine for months.
Here is the log link:
http://logs.volumio.org/rivo/TdJ3r25.html
