Upon starting Rivo + remote the UI alternatively flashes three conflicting messages; “The selected output device is not available”, then “Configuration update, player successfully restarted”, then “USB DAC Connected D90SE”.
I tried restarting Rivo, and the remote, no change. Hard restart (unplugged) no change. Changed to different USB cable, no change. Changed to coax input, no change. Incessantly flashes between same three messages.
Will not play. Other sources into DAC play. Please advise.
