Hello, I just received my Rivo+. When playing dsf files ripped from SACD through the microsd card, my McIntosh D150 DAC only shows DSD64 with the setting on the Rivo at “DSD over PCM (Dop)”. The D150 supports “Direct DSD”, so, how do I get that working on the Rivo+, ie. the “DSD direct” setting. Note: The D150 is automatically recognized by the Rivo+ in the “Output device” setting. Thanks in advance for any help.
could you please provide a system log?
Most probably, the manufacturer of your DAC did not register the device in the official Linux kernel for DSD support, that’s why you don’t get DSD playback with Volumio. With the system log we can verify this assumption.
Please be aware this is not a fault of Volumio, but a (quite common) lack from the manufacturer. Most of the manufacturers of DSD-direct capable DACs take care of Windows users only, and lack support for Linux.
For overcoming this problem, we patch the official Linux kernel for adding DSD support to additional DACs, we will try to do the same for your device in the future releases (no ETA).
Ok, I generated the log while I was playing SACD ripped to DSF files on the microsd card on the Rivo+. The setting is “DSD over PCM (Dop)”. If I set it to “DSD Direct” it converts the dsf files to PCM. Here is the link to the log file. Let me know if you need anything else, or if you need me to generate the log with the “DSD Direct” flag enabled on dsf sources. Please fix asap. Thanks so much !!
http://logs.volumio.org/rivoplus/leP9xZg.html
Ok, I generated the log while I was playing SACD ripped to DSF files on the microsd card on the Rivo+. The setting is “DSD over PCM (Dop)”. If I set it to “DSD Direct” it converts the dsf files to PCM. Here is the link to the log file and a copy/paste into this post. Let me know if you need anything else, or if you need me to generate the log with the “DSD Direct” flag enabled on dsf sources. Please fix asap. Thanks so much !!
Wed May 7 07:45:59 PDT 2025
Description="'McIntosh D150 Direct DSD DAC gets DSD converted to PCM on Rivo+ using DSD Direct'"
# cat /proc/version ---------------
Linux version 4.9.241 (paolo@volumio-build) (gcc version 9.4.0 (Ubuntu 9.4.0-1ubuntu1~20.04.1) ) #2 SMP PREEMPT Sat Dec 14 12:27:06 CET 2024
# cat /etc/os-release ---------------
PRETTY_NAME="Debian GNU/Linux 10 (buster)"
NAME="Debian GNU/Linux"
VERSION_ID="10"
VERSION="10 (buster)"
VERSION_CODENAME=buster
ID=debian
HOME_URL="https://www.debian.org/"
SUPPORT_URL="https://www.debian.org/support"
BUG_REPORT_URL="https://bugs.debian.org/"
VOLUMIO_BUILD_VERSION="147953990fca4aa103a8f90538ef56fb0454638c"
VOLUMIO_FE_VERSION="e7cae168f9927391640a091813b8a9656b6909b6"
VOLUMIO_FE3_VERSION="df82a8f23c90a3617c15c55572c8aaea90d8b32a"
VOLUMIO_BE_VERSION="9ab87de061b3649c303da550e73c92d340b0f989"
VOLUMIO_ARCH="armv7"
VOLUMIO_VARIANT="rivoplus"
VOLUMIO_TEST="FALSE"
VOLUMIO_BUILD_DATE="Wed 30 Apr 2025 11:06:47 AM CEST"
VOLUMIO_VERSION="3.807"
VOLUMIO_HARDWARE="mp1"
VOLUMIO_DEVICENAME="Volumio MP1"
VOLUMIO_VENDOR_MODEL="Volumio Rivo"
VOLUMIO_VENDOR="Volumio"
VOLUMIO_MODEL="Rivo"
VOLUMIO_HASH="f92ac0ecb6de863dba28fedfed23f19e"
# ifconfig ---------------
dummy0: flags=195 mtu 1500
ether 4e:fa:9f:9d:18:c8 txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 10 bytes 3920 (3.8 KiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
eth0: flags=4099 mtu 1500
ether 02:00:00:18:34:01 txqueuelen 1000 (Ethernet)
TX packets 0 bytes 0 (0.0 B)
device interrupt 13
lo: flags=73 mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
loop txqueuelen 1 (Local Loopback)
RX packets 5371 bytes 1084401 (1.0 MiB)
TX packets 5371 bytes 1084401 (1.0 MiB)
wlan0: flags=4163 mtu 1500
inet 192.168.1.86 netmask 255.255.255.0 broadcast 192.168.1.255
ether 54:78:c9:8f:83:6a txqueuelen 1000 (Ethernet)
RX packets 2776 bytes 618655 (604.1 KiB)
TX packets 2822 bytes 1941168 (1.8 MiB)
# sudo iwconfig ---------------
sit0 no wireless extensions.
ip_vti0 no wireless extensions.
tunl0 no wireless extensions.
ip6tnl0 no wireless extensions.
eth0 no wireless extensions.
ip6_vti0 no wireless extensions.
lo no wireless extensions.
dummy0 no wireless extensions.
wlan0 IEEE 802.11 ESSID:"ATT6bt6JuI"
Mode:Master Frequency:5.54 GHz Access Point: D4:B2:7A:84:8D:CA
Bit Rate=234 Mb/s Tx-Power:32 dBm
Retry min limit:7 RTS thr:off Fragment thr:off
Encryption key:off
Power Managementmode:All packets received
Link Quality=2/5 Signal level=-73 dBm Noise level=-92 dBm
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:0 Missed beacon:0
# aplay -l ---------------
card 0: AMLAUGESOUNDMP1 [AML-AUGESOUND-MP1], device 0: TDM-B-dummy-HDMI_SPDIF_I2S dummy-0 []
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: AMLAUGESOUNDMP1 [AML-AUGESOUND-MP1], device 1: SPDIF-B-dit-hifi-HDMI dit-hifi-1 []
Subdevices: 1/1
card 0: AMLAUGESOUNDMP1 [AML-AUGESOUND-MP1], device 2: SPDIF-dit-hifi-HDMI_SPDIF dit-hifi-2 []
Subdevices: 1/1
card 0: AMLAUGESOUNDMP1 [AML-AUGESOUND-MP1], device 3: TDM-A-dummy-BLUETOOTH dummy-3 []
Subdevices: 1/1
card 0: AMLAUGESOUNDMP1 [AML-AUGESOUND-MP1], device 4: TDM-C-dummy dummy-4 []
Subdevices: 1/1
card 0: AMLAUGESOUNDMP1 [AML-AUGESOUND-MP1], device 5: EARC/ARC-dummy-eARC dummy-5 []
Subdevices: 1/1
card 1: Device [Comtrue-inc UAC2 Device], device 0: USB Audio [USB Audio]
Subdevices: 1/1
card 5: D150 [D150], device 0: USB Audio [USB Audio]
Subdevices: 0/1
# lsusb ---------------
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 006: ID 2fc6:6016
Bus 001 Device 005: ID 2afd:0002
Bus 001 Device 004: ID 2e8a:0005
Bus 001 Device 003: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub
Bus 001 Device 002: ID 1a40:0101 Terminus Technology Inc. Hub
# lsusb -t ---------------
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 5000M
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/2p, 480M
|__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 480M
|__ Port 4: Dev 3, If 0, Class=Hub, Driver=hub/3p, 480M
|__ Port 1: Dev 4, If 0, Class=Communications, Driver=cdc_acm, 12M
|__ Port 1: Dev 4, If 1, Class=CDC Data, Driver=cdc_acm, 12M
|__ Port 2: Dev 5, If 0, Class=Human Interface Device, Driver=usbhid, 480M
|__ Port 2: Dev 5, If 1, Class=Audio, Driver=snd-usb-audio, 480M
|__ Port 2: Dev 5, If 2, Class=Audio, Driver=snd-usb-audio, 480M
|__ Port 3: Dev 6, If 0, Class=Audio, Driver=snd-usb-audio, 480M
|__ Port 3: Dev 6, If 1, Class=Audio, Driver=snd-usb-audio, 480M
# lsusb -v ---------------
Couldn't open device, some information will be missing
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 3.00
bDeviceClass 9 Hub
bDeviceSubClass 0
bDeviceProtocol 3
bMaxPacketSize0 9
idVendor 0x1d6b Linux Foundation
idProduct 0x0003 3.0 root hub
bcdDevice 4.09
iManufacturer 3
iProduct 2
iSerial 1
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 0x001f
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 9 Hub
bInterfaceSubClass 0
bInterfaceProtocol 0 Full speed (or root) hub
iInterface 0
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x0004 1x 4 bytes
bInterval 12
bMaxBurst 0
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 239 Miscellaneous Device
bDeviceSubClass 2
bDeviceProtocol 1 Interface Association
bMaxPacketSize0 64
idVendor 0x2fc6
idProduct 0x6016
bcdDevice 2.01
iManufacturer 1
iProduct 2
iSerial 3
bLength 9
bDescriptorType 2
wTotalLength 0x0137
bNumInterfaces 2
iConfiguration 0
bmAttributes 0xc0
Self Powered
MaxPower 0mA
Interface Association:
bLength 8
bDescriptorType 11
bFirstInterface 0
bInterfaceCount 2
bFunctionClass 1 Audio
bFunctionSubClass 0
bFunctionProtocol 32
iFunction 0
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 0
bInterfaceClass 1 Audio
bInterfaceSubClass 1 Control Device
bInterfaceProtocol 32
iInterface 2
AudioControl Interface Descriptor:
bLength 9
bDescriptorType 36
bDescriptorSubtype 1 (HEADER)
bcdADC 2.00
bCategory 4
wTotalLength 0x0040
bmControls 0x00
bLength 8
bDescriptorType 36
bDescriptorSubtype 10 (CLOCK_SOURCE)
bClockID 5
bmAttributes 3 Internal programmable clock
bmControls 0x07
Clock Frequency Control (read/write)
Clock Validity Control (read-only)
bAssocTerminal 0
iClockSource 0
bLength 17
bDescriptorType 36
bDescriptorSubtype 2 (INPUT_TERMINAL)
bTerminalID 1
wTerminalType 0x0101 USB Streaming
bAssocTerminal 0
bCSourceID 5
bNrChannels 2
bmChannelConfig 0x00000003
Front Left (FL)
Front Right (FR)
iChannelNames 0
bmControls 0x0000
iTerminal 0
bLength 18
bDescriptorType 36
bDescriptorSubtype 6 (FEATURE_UNIT)
bUnitID 3
bSourceID 1
bmaControls(0) 0x0000000f
Mute Control (read/write)
Volume Control (read/write)
bmaControls(1) 0x0000000c
bmaControls(2) 0x0000000c
iFeature 0
bLength 12
bDescriptorType 36
bDescriptorSubtype 3 (OUTPUT_TERMINAL)
bTerminalID 4
wTerminalType 0x0301 Speaker
bAssocTerminal 0
bSourceID 3
bCSourceID 5
bmControls 0x0000
iTerminal 0
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 0
bInterfaceSubClass 2 Streaming
iInterface 4
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 1
bNumEndpoints 2
iInterface 0
AudioStreaming Interface Descriptor:
bLength 16
bDescriptorType 36
bDescriptorSubtype 1 (AS_GENERAL)
bTerminalLink 1
bmControls 0x05
Active Alternate Setting Control (read-only)
Valid Alternate Setting Control (read-only)
bFormatType 1
bmFormats 0x00000001
PCM
bNrChannels 2
Front Left (FL)
Front Right (FR)
iChannelNames 0
bLength 6
bDescriptorType 36
bDescriptorSubtype 2 (FORMAT_TYPE)
bFormatType 1 (FORMAT_TYPE_I)
bSubslotSize 2
bBitResolution 16
bLength 7
bDescriptorType 5
bEndpointAddress 0x01 EP 1 OUT
bmAttributes 5
Transfer Type Isochronous
Synch Type Asynchronous
Usage Type Data
wMaxPacketSize 0x0308 1x 776 bytes
bInterval 1
AudioStreaming Endpoint Descriptor:
bLength 8
bDescriptorType 37
bDescriptorSubtype 1 (EP_GENERAL)
bmAttributes 0x00
bmControls 0x00
bLockDelayUnits 0 Undefined
wLockDelay 0x0000
bLength 7
bDescriptorType 5
bmAttributes 17
Synch Type None
Usage Type Feedback
bInterval 4
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 2
bNumEndpoints 2
iInterface 0
bLength 16
bDescriptorType 36
bTerminalLink 1
bmControls 0x05
bFormatType 1
PCM
bNrChannels 2
Front Left (FL)
Front Right (FR)
iChannelNames 0
bLength 6
bDescriptorType 36
bSubslotSize 3
bBitResolution 24
bLength 7
bDescriptorType 5
bmAttributes 5
Usage Type Data
bInterval 1
bLength 8
bDescriptorType 37
bmAttributes 0x00
bmControls 0x00
wLockDelay 0x0000
bLength 7
bDescriptorType 5
bmAttributes 17
Synch Type None
Usage Type Feedback
bInterval 4
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 3
bNumEndpoints 2
iInterface 0
bLength 16
bDescriptorType 36
bTerminalLink 1
bmControls 0x05
bFormatType 1
PCM
bNrChannels 2
Front Left (FL)
Front Right (FR)
iChannelNames 0
bLength 6
bDescriptorType 36
bSubslotSize 4
bBitResolution 32
bLength 7
bDescriptorType 5
bmAttributes 5
Usage Type Data
bInterval 1
bLength 8
bDescriptorType 37
bmAttributes 0x00
bmControls 0x00
wLockDelay 0x0000
bLength 7
bDescriptorType 5
bmAttributes 17
Synch Type None
Usage Type Couldn't open device, some information will be missing
Feedback
bInterval 4
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 4
bNumEndpoints 2
iInterface 0
bLength 16
bDescriptorType 36
bTerminalLink 1
bmControls 0x05
bFormatType 1
bmFormats 0x80000000
bNrChannels 2
Front Left (FL)
Front Right (FR)
iChannelNames 0
bLength 6
bDescriptorType 36
bSubslotSize 4
bBitResolution 32
bLength 7
bDescriptorType 5
bmAttributes 5
Usage Type Data
bInterval 1
bLength 8
bDescriptorType 37
bmAttributes 0x00
bmControls 0x00
wLockDelay 0x0000
bLength 7
bDescriptorType 5
bmAttributes 17
Synch Type None
Usage Type Feedback
bInterval 4
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceSubClass 2
bMaxPacketSize0 64
idVendor 0x2afd
idProduct 0x0002
bcdDevice 0.01
iManufacturer 1
iProduct 2
iSerial 0
bLength 9
bDescriptorType 2
wTotalLength 0x011b
bNumInterfaces 3
iConfiguration 0
bmAttributes 0x80
(Bus Powered)
MaxPower 100mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 3 Human Interface Device
iInterface 0
HID Device Descriptor:
bLength 9
bDescriptorType 33
bcdHID 1.00
bCountryCode 0 Not supported
bNumDescriptors 1
bDescriptorType 34 Report
wDescriptorLength 99
Report Descriptors:
** UNAVAILABLE **
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
wMaxPacketSize 0x0020 1x 32 bytes
bInterval 6
bLength 8
bDescriptorType 11
bFirstInterface 1
bInterfaceCount 2
bFunctionSubClass 0
iFunction 3
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 0
iInterface 3
bLength 9
bDescriptorType 36
bcdADC 2.00
bCategory 10
wTotalLength 0x0040
bmControls 0x00
bLength 8
bDescriptorType 36
bClockID 1
bmAttributes 7 Internal programmable clock (synchronized to SOF)
bmControls 0x07
bAssocTerminal 0
iClockSource 0
bLength 17
bDescriptorType 36
bTerminalID 3
bAssocTerminal 0
bCSourceID 1
bNrChannels 2
Front Left (FL)
Front Right (FR)
iChannelNames 0
bmControls 0x0000
iTerminal 0
bLength 12
bDescriptorType 36
bTerminalID 4
bAssocTerminal 0
bSourceID 10
bCSourceID 1
bmControls 0x0000
iTerminal 0
bLength 18
bDescriptorType 36
bUnitID 10
bSourceID 3
bmaControls(0) 0x00000003
iFeature 0
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 0
bNumEndpoints 0
iInterface 0
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 1
bNumEndpoints 2
iInterface 0
bLength 16
bDescriptorType 36
bTerminalLink 3
bmControls 0x00
bFormatType 1
PCM
bNrChannels 2
Front Left (FL)
Front Right (FR)
iChannelNames 0
bLength 6
bDescriptorType 36
bSubslotSize 2
bBitResolution 16
bLength 7
bDescriptorType 5
bEndpointAddress 0x03 EP 3 OUT
bmAttributes 5
Usage Type Data
wMaxPacketSize 0x00c8 1x 200 bytes
bInterval 1
bLength 8
bDescriptorType 37
bmAttributes 0x00
bmControls 0x00
bLockDelayUnits 2 Decoded PCM samples
wLockDelay 0x0002
bLength 7
bDescriptorType 5
bEndpointAddress 0x84 EP 4 IN
bmAttributes 17
Synch Type None
Usage Type Feedback
bInterval 4
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 2
bNumEndpoints 2
iInterface 0
bLength 16
bDescriptorType 36
bTerminalLink 3
bmControls 0x00
bFormatType 1
PCM
bNrChannels 2
Front Left (FL)
Front Right (FR)
iChannelNames 0
bLength 6
bDescriptorType 36
bSubslotSize 3
bBitResolution 24
bLength 7
bDescriptorType 5
bmAttributes 5
Usage Type Data
wMaxPacketSize 0x012c 1x 300 bytes
bInterval 1
bLength 8
bDescriptorType 37
bmAttributes 0x00
bmControls 0x00
wLockDelay 0x0002
bLength 7
bDescriptorType 5
bmAttributes 17
Synch Type None
Usage Type Feedback
bInterval 4
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 3
bNumEndpoints 2
iInterface 0
bLength 16
bDescriptorType 36
bTerminalLink 3
bmConCouldn't open device, some information will be missing
trols 0x00
bFormatType 1
PCM
bNrChannels 2
Front Left (FL)
Front Right (FR)
iChannelNames 0
bLength 6
bDescriptorType 36
bSubslotSize 4
bBitResolution 32
bLength 7
bDescriptorType 5
bmAttributes 5
Usage Type Data
wMaxPacketSize 0x0190 1x 400 bytes
bInterval 1
bLength 8
bDescriptorType 37
bmAttributes 0x00
bmControls 0x00
wLockDelay 0x0002
bLength 7
bDescriptorType 5
bmAttributes 17
Synch Type None
Usage Type Feedback
bInterval 4
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceSubClass 2
bMaxPacketSize0 64
idVendor 0x2e8a
idProduct 0x0005
bcdDevice 1.00
iManufacturer 1
iProduct 2
iSerial 3
bLength 9
bDescriptorType 2
wTotalLength 0x004b
bNumInterfaces 2
iConfiguration 0
bmAttributes 0x80
(Bus Powered)
MaxPower 250mA
bLength 8
bDescriptorType 11
bFirstInterface 0
bInterfaceCount 2
bFunctionClass 2 Communications
bFunctionSubClass 2 Abstract (modem)
bFunctionProtocol 0
iFunction 0
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 2 Communications
bInterfaceSubClass 2 Abstract (modem)
iInterface 4
CDC Header:
bcdCDC 1.20
CDC Call Management:
bmCapabilities 0x00
bDataInterface 1
CDC ACM:
bmCapabilities 0x06
sends break
line coding and serial state
CDC Union:
bMasterInterface 0
bSlaveInterface 1
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
wMaxPacketSize 0x0008 1x 8 bytes
bInterval 16
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 10 CDC Data
bInterfacePrCouldn't open device, some information will be missing
otocol 0
iInterface 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x02 EP 2 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0040 1x 64 bytes
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x82 EP 2 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 9 Hub
bDeviceSubClass 0
bDeviceProtocol 2 TT per port
bMaxPacketSize0 64
idVendor 0x0424 Standard Microsystems Corp.
idProduct 0x2514 USB 2.0 Hub
bcdDevice b.b3
iManufacturer 0
iProduct 0
iSerial 0
bLength 9
bDescriptorType 2
wTotalLength 0x0029
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 2mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceProtocol 1 Single TT
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
wMaxPacketSize 0x0001 1x 1 bytes
bInterval 12
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 1
bNumEndpoints 1
bInterfaceProtocol 2 TT per port
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 12
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 9 Hub
bDeviceSubClass 0
bDeviceProtocol 1 Single TT
bMaxPacketSize0 64
idVendor 0x1a40 Terminus Technology Inc.
idProduct 0x0101 Hub
bcdDevice 1.11
iManufacturer 0
iProduct 1
iSerial 0
bLength 9
bDescriptorType 2
wTotalLength 0x0019
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 100mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfCouldn't open device, some information will be missing
aceClass 9 Hub
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 12
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 9 Hub
bDeviceSubClass 0
bMaxPacketSize0 64
idProduct 0x0002 2.0 root hub
bcdDevice 4.09
iManufacturer 3
iProduct 2
iSerial 1
bLength 9
bDescriptorType 2
wTotalLength 0x0019
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 12
