I have playlists created in Spotify that are imported into Qobuz and modified with missing tracks that are found only on Tidal. These playlist exist in my Roon account. These playlists have tracks that consist of Qobuz and Tidal music.
I can import the Qobuz playlist into the Rivo+ via the Qobuz connect interface, but I have to go and manually locate the missing tracks in Tidal and enter them into the Rivo+ playlist.
This is time consuming and i would like to be able to backup those playlist created in the Rivo+
Is there a way to do that?
It would be incredible if I could import my Roon playlists into the Rivo+ since the playlist work is already done in Roon, but either way backing up the many playlists I have is important.
I’m hoping to stop paying for Roon.
Thanks in advance,
Ted
