New to this forum.
I will be receiving my Rivo tomorrow. I will be running it via a Pine Tree Audio LPS that I currently use for my Wiim Pro. It has the correct spec’s for the Rivo in case anyone was wondering.
For all of the current users, did you find there was a break-in/burn-in period for the Rivo? I want to be sure that my SQ expectations “out of the box” are realistic.
For what is worth I never noticed a change in sound with burn in with Rivo.
That was instead the case with Integro…
Thank you!
