E: Sub-process /usr/bin/dpkg returned an error code (1)
Raspberry PI 2 Model B
During update firmware with this command
sudo apt-get update && sudo apt-get upgrade
How to solve?
thanks,
Arnaldo.
How to solve?
thanks,
Arnaldo.
Don’t do it, it will break your Volumio installation
Just to clarify, sudo apt-get update should be ok, but sudo apt-get upgrade is very likely to break the optimised Volumio packages.
Ok, great!
Thanks,
Aranldo.
