Resize partition in Volumio 2
I went to resize the partition to fill the SD card, but found that raspi-config is not installed (or at least not in the default path).
  1. Is raspi-config not included with Volumio 2?
  2. Is their an alternative for raspi-config functionality (e.g., resize partition)?
That can be found here: raspberrypi.stackexchange.com/qu … -partition
But Volumio 2 uses all of the 8GB I inserted into it, didn’t need to resize.
Correct, Volumio will automatically re-size upon first boot.
All available space will be added to the data partition (partition #3).
