Can I reset alsa from the commandline? I tried an “alsactl” command but this command is not recognised? Also “sudo alsa force-reload” gives me an error that the command “alsa” is not recognised?
I think you need to use sudo with alsactl??
forgot to write it but used “sudo” with the command
