Ikyo
September 25, 2023, 1:00pm
1
Prerequisites
Volumio Information
Volumio Version:3
Hardware: rpi4
DAC: SMSL sanskrit 10th mkII
Debug Log
Steps to Reproduce
Additional Information
After each os update, the library is lost but the NAS folders still in place. Needed to rescan all the folders.
volumio
September 25, 2023, 4:44pm
4
This is a test build, which has some features that we are testing (like rescan if database is empty).
Why did you update to this BETA version?
You can reinstall the official release and this issue will not be there
Ikyo
September 25, 2023, 5:59pm
5
Ok wellnoted
I’ve to check the reason why the interface shown me this update proposal.
Tks
Wheaten
September 25, 2023, 6:09pm
6
Please disable the test mode in:
//<ip-address>/dev
This should only be enabled on Volumio’s request or if you like to walk the experimental road. (and take errors for granted as those test releases are mend for specific testing, which might break other functionalities)
volumio
September 25, 2023, 6:15pm
7
Did you enable test mode? Where you got your image or system?
Ikyo
September 28, 2023, 1:58pm
8
tes Pb solved, I’ve deactivated the test mode.
Tks at all !
