The “resampling (bit depth)” feature in the playback options works for the internal volumio player but does not work for the streaming service “tidal connect”.
Tidal Connect is spitting out the actual bit depth of the song even with the “resampling (bit depth)” feature enabled in the playback options of Volumio.
My DAC (Soekris DAM1021) does not accept 16bit, and therefore I can’t use Tidal connect because 90% of the songs are 16 bit.
Volumio Information
Volumio Version: 3.832
Hardware: Raspberry PI3+
DAC: Soekris DAM1021
Steps to Reproduce
- Go to: settings → playback options
- Enable “resampling - bit depth” to 24 or 32 bits
- Start playback a song with 44.1khz-16Bit via Tidal Connect.
