Replaygain info reading in MPD (mpd.conf) - chance of official support on volumio?
Hi developers,
Searching on web about replaygain support on MPD made me check the file mpd.conf on volumio.
I came across this line:
#replaygain “album”
which means it’s not used… I changed it (at my own risk) to:
replaygain “album”
Well… no success on applying replaygain info on metada of files…
I tried with files with the following info:
ALBUMGAIN -9.08000
ALBUMPEAK 1.00000
TRACKGAIN -9.35000
TRACKPEAK 0.99335
I really love playing files reading replaygain album gain, since it makes “average” album volume similar across albuns…
Any idea why this doesn’t work?
Any change of supporting this options officialy in volumio? :ok_hand:
Something like on playing option menu:
Use replaygain info? (yes / no)
replay gain type? (album / track)
Thanks in advance!
BR,
Paulo Nunes
