Volumio Information
Volumio Version: v2.917
Hardware: Raspberry Pi 2 Model B Rev 1.1
DAC: Schiit
I have an USB HDD Toshiba DTB310, formatted in Ext4 with all my music in Music folder.
To view it on volumio, I create a symlink as this :
sudo ln -s /media/ToshibaExt/Music/ /mnt/USB
I want to replace it because of strange mechanical noises on it.
I bought a Samsung T7 SSD. I formatted in Ext4 and copy music folder on it.
I replace symlink as this:
sudo unlink /mnt/USB
sudo ln -s /media/samsung1TO/Music/ /mnt/USB
When I replace my HDD by SSD, Volumio dont see it.
Symlink and mount seems good:
HDD:
volumio@volumio:~$ ll /mnt/
total 8
drwxrwxrwx 1 root root 4096 Oct 23 08:57 .
drwxrwxrwx 1 root root 4096 Oct 1 2019 ..
lrwxrwxrwx 1 root root 14 Oct 6 10:34 INTERNAL -> /data/INTERNAL
drwxrwxrwx 2 root root 3 Oct 6 10:34 NAS
drwxrwxrwx 2 root root 3 Oct 6 10:34 UPNP
lrwxrwxrwx 1 root root 24 Oct 23 08:57 USB -> /media/ToshibaExt/Music/
volumio@volumio:~$ ll /mnt/USB
lrwxrwxrwx 1 root root 24 Oct 23 08:57 /mnt/USB -> /media/ToshibaExt/Music/
volumio@volumio:~$ ll /mnt/USB/
total 440
drwxrwxr-x 110 volumio volumio 4096 Jun 16 07:50 .
drwxrwxr-x 9 volumio volumio 4096 Oct 20 15:34 ..
drwxrwxr-x 3 volumio volumio 4096 Jun 30 2016 2 Many DJ's
SSD:
total 8
drwxrwxrwx 1 root root 4096 Oct 24 08:41 .
lrwxrwxrwx 1 root root 24 Oct 24 08:41 USB -> /media/samsung1TO/Music/
lrwxrwxrwx 1 root root 24 Oct 24 08:41 /mnt/USB -> /media/samsung1TO/Music/
total 440
drwx------ 8 volumio volumio 4096 Oct 20 16:08 ..
When I plug HDD:
volumio@volumio:~$ cat /var/log/mpd.log
Oct 24 09:12 : client: [3] opened from local
Oct 24 09:12 : client: [4] opened from local
Oct 24 09:12 : exception: Failed to access /var/lib/mpd/music/USB: Permission denied
Oct 24 09:12 : client: [3] closed
Oct 24 09:12 : client: [4] closed
Oct 24 09:12 : client: [5] opened from local
Oct 24 09:12 : client: [5] closed
Oct 24 09:12 : update: added USB/Daft Punk/Alive 2007/01 - Robot Rock _ Oh Yeah.mp3
dmesg
[ 459.654954] usb 1-1.2: USB disconnect, device number 6
[ 459.656340] print_req_error: I/O error, dev sda, sector 0
[ 459.664253] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[ 459.664431] sd 0:0:0:0: [sda] Synchronize Cache(10) failed: Result: hostbyte=0x01 driverbyte=0x00
[ 463.997401] Under-voltage detected! (0x00050005)
[ 464.297287] usb 1-1.2: new high-speed USB device number 7 using dwc_otg
[ 464.429502] usb 1-1.2: New USB device found, idVendor=0480, idProduct=a200, bcdDevice= 0.00
[ 464.429521] usb 1-1.2: New USB device strings: Mfr=2, Product=3, SerialNumber=1
[ 464.429533] usb 1-1.2: Product: External USB 3.0
[ 464.429544] usb 1-1.2: Manufacturer: TOSHIBA
[ 464.429555] usb 1-1.2: SerialNumber: 20150901016626F
[ 464.430716] usb-storage 1-1.2:1.0: USB Mass Storage device detected
[ 464.432406] scsi host0: usb-storage 1-1.2:1.0
[ 465.438596] scsi 0:0:0:0: Direct-Access TOSHIBA External USB 3.0 0 PQ: 0 ANSI: 6
[ 465.440168] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 467.285160] sd 0:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[ 467.285805] sd 0:0:0:0: [sda] Write Protect is off
[ 467.285818] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00
[ 467.287930] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 467.302718] sda: sda1
[ 467.305976] sd 0:0:0:0: [sda] Attached SCSI disk
[ 467.903189] EXT4-fs (sda1): warning: mounting fs with errors, running e2fsck is recommended
[ 467.973599] EXT4-fs (sda1): recovery complete
[ 467.973716] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 470.237327] Voltage normalised (0x00000000)
When I plug SSD:
Oct 23 22:35 : zeroconf: No global port, disabling zeroconf
Oct 23 22:35 : client: [0] opened from local
Oct 24 08:38 : client: [0] closed
Oct 24 08:38 : client: [1] opened from local
Oct 24 08:38 : client: [2] opened from 127.0.0.1:36898
Oct 24 08:41 : client: [3] opened from local
Oct 24 08:41 : client: [3] closed
Oct 24 08:41 : exception: Failed to access /var/lib/mpd/music/USB: No such file or directory
Oct 24 08:41 : update: removing USB/Amadou & Mariam/Folila/04 - Metemya.mp3
dmesg
[ 262.057927] usb 1-1.2: new high-speed USB device number 6 using dwc_otg
[ 262.189587] usb 1-1.2: New USB device found, idVendor=04e8, idProduct=4001, bcdDevice= 1.00
[ 262.189606] usb 1-1.2: New USB device strings: Mfr=2, Product=3, SerialNumber=1
[ 262.189614] usb 1-1.2: Product: PSSD T7
[ 262.189621] usb 1-1.2: Manufacturer: Samsung
[ 262.189629] usb 1-1.2: SerialNumber: S6TWNJ0R904802X
[ 262.192123] usb 1-1.2: The driver for the USB controller dwc_otg_hcd does not support scatter-gather which is
[ 262.192138] usb 1-1.2: required by the UAS driver. Please try an other USB controller if you wish to use UAS.
[ 262.192148] usb-storage 1-1.2:1.0: USB Mass Storage device detected
[ 262.193092] scsi host0: usb-storage 1-1.2:1.0
[ 263.204197] scsi 0:0:0:0: Direct-Access Samsung PSSD T7 0 PQ: 0 ANSI: 6
[ 263.205245] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 263.206622] sd 0:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[ 263.207227] sd 0:0:0:0: [sda] Write Protect is off
[ 263.207247] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00
[ 263.208102] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 263.218284] sda: sda1
[ 263.222991] sd 0:0:0:0: [sda] Attached SCSI disk
[ 263.804864] EXT4-fs (sda1): recovery complete
[ 263.804899] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
