FYI (unless you try to avoid using the IR Controller plugin): I will open a PR for a buster capable version of the IR Controller plugin on GitHub soon.
So, it looks as though rc.local has been deprecated … presumably because of conflicts with systemd and sysv. Answer to OP is to create a suitable systemd service file.
