I am using the IR Remote control plugin in conjunction with the Justboom IR RC on Volumio running on a RasPi. However, my housemates use too often the OFF-button to start/stop Volumio witch switches off my RasPi, hence frustration.
So I want to disable this button. Been searching internet and found this can be done in the lirc config. However I can not locate where this config is nor what the right procedure/commands are to change it.
Some help here will be highly appreciate by me and my housemates.
As a second question: how can I change the blue color in a ssh-terminal as it makes reading very hard. Treid to change the .bashrc file in the home folder of volumio-account but that didn’t help at all.
I have packaged a modified profile for the JustBoom remote without the power off function. You just have to download the attached .zip file, extract it and copy / move the extracted folder “JustBoom IR Remote” and its content to /data/INTERNAL/ir_controller/configurations
“INTERNAL” should be accessible as a samba share e.g. from a PC so you can easily access its subfolders via samba, too. A configuration in “/data/INTERNAL/ir_controller/configurations” gains priority over an identically named profile in the factory profiles folder (“/data/plugins/accessory/ir_controller/configurations”).
If you already have selected “JustBoom IR Remote” as remote temporarily select another remote and click “Save”. Then re-select “JustBoom IR Remote” and click “Save” again.
Thx for all this. So I select an IR-controller different from JB and save and close Plugins. Copy your folder to /data/INTERNAL/ir_controller/configurations (using WinSCP)
I reopen Plugins, and reselect JB IR but get an error in saving setting. Waiting till error disappears , and hitting “save” again, works well now. Hmm!!?? Strange behavio but OK.
Thx again
NB: Later on I renamed the folder to “JustBoom IR Remote-OFF” which makes it popup as a second JB IR but with the adition “-OFF” in the list of known IR controllers. So, doing so makes it more obvious which I am selecting .
