What an odyssey…
good friends hello … can you tell me if I want to install this plugin witch on volumio 3 how can I do?
Auto_play
GPIO Buttons
LEDStatus
The IR Remote Controller plugin is not yet available for Volumio 3, but I will create a PR on GitHub soon.
but what if i want to test it anyway and also install the other three i have to use?
how can i use the wget command?
Plugins that work on Volumio 2 will not necessarily work with Volumio 3. gvolt has said that the IR Remote isn’t yet ready for the Buster upgrade. You will just have to wait, unfortunately.
Ok… but I interested the other three plug-in!
