Is it possible to reinstall or repair my Volumio image using ssh? The case I have is a pain to put together and does not provide access to the SD card. I was messing around with my router and NAS and now the Volumio GUI won’t load. The log file is empty.
I’m able to ssh in and made a backup file. When I type “volumio” I get the commands listed, but when I type them, I get things like this.
“curl: (7) Failed to connect to 127.0.0.1 port 3000: Connection refused”
So if I can do something to reinstall from the command line, that’d be great. Otherwise I’ll tear it apart and reflash it.
I used the tar backup process from chsims (oh – that’s you!!!) elsewhere in the forum. It crashed during the restore, but the GUI worked, so factory reset 2nd time via GUI. I don’t see a backup plugin when I search from within gui. Is there another place to look? My setup isn’t too complicated. So after setting up 5-10 web radio stations, and rescanning my library, I’m good to go.
Oddly, it put me back to 2.175. Some things were weird and it took me a while to check that. Went through the update cycle a couple of time times. Everything seems good now.
