Hi Everyone,
I’m using actually Volumio since a while with Nanosound DAC (1st generation) with volume disabled connected to a Sansui AU-717 amp, I’m pretty happy with the results, the thing is when I play music, the DAC outputs quite high volume/gain so I have to set the Sansui’s volume very low, almost 1-2 steps from the minimum, so I would like to ask you whether there’s a way to reduce the gain of the DAC to something like 50% keeping the volume mixer disabled, I’m aware that volume itself tunes the gain but if I activate software volume it will reduce sound quality and hardware mixer makes nothing to the volume, just doesn’t react.
Any hint will be appreciated!
Cheers,
Bruno
