Recommended (and curently available) 5Ghz USB dongle compatible with Volumio 3.xxx?
Please, it seems to be impossible to find a recommendation on Wifi USB dongles. Could someone please recommend one? :slight_smile:
Running Rpi3B+ :slight_smile:
Thank you :slight_smile:
Could you say on which platform you installed Volumio (PI, Tinkerboard, x86)?
Wifi dongle support depends on the platform used.
Sorry, totally forgot that there are other platforms than Rpi also. Running Rpi3B+ :slight_smile:
