I finally got my new DIY streamer up and running using a Raspberry Pi 3B+, 5" DSI display and a HiFiBerry DAC2 Pro. It all works great, but it frequently complains about being undervolted (i.e. it shows the lightning bolt on the display much of the time). I’m using a CanaKit RPi 3 power supply which provides 5.1V at 2.5A (pretty much the same as the official RPi power supply) - my main issue is that I’ve had bad luck with power supplies not made by the RPi Foundation or CanaKit, even at higher current outputs, and there doesn’t really seem to be any ‘official’ options that provide more than 2.5A.
Has anyone found a decent power supply that provides consistent power in the 3-4A range that has a Micro USB connector, or does anyone have any suitable alternative? Being undervolted hasn’t affected the performance any, but I don’t like the lightning bolt sitting there taunting me.
