with version 2.368 when I want to add all my library (8876 titles) in a playlist, the animation is waiting and then I come back to the main page with the sound when Volumio starts.
I can add and listen to albums by albums, song by song
I reproduced the process and just after clicking Replace and play I have this message in the log file volumio.log
2018-02-25T07:42:00.561Z - info: CoreCommandRouter::volumioReplaceandPlayItems
2018-02-25T07:42:05.374Z - info: -------------------------------------------
2018-02-25T07:42:05.386Z - info: ----- Volumio2 ----
2018-02-25T07:42:05.388Z - info: -------------------------------------------
2018-02-25T07:42:05.388Z - info: ----- System startup ----
2018-02-25T07:42:05.389Z - info: -------------------------------------------
2018-02-25T07:42:05.546Z - info: Plugin folders cleanup
2018-02-25T07:42:05.547Z - info: Scanning into folder /volumio/app/plugins/
2018-02-25T07:42:05.548Z - info: Scanning category audio_interface
2018-02-25T07:42:05.551Z - info: Scanning category miscellanea
2018-02-25T07:42:05.554Z - info: Scanning category music_service
2018-02-25T07:42:05.556Z - info: Scanning category plugins.json
2018-02-25T07:42:05.559Z - info: Scanning category system_controller
2018-02-25T07:42:05.563Z - info: Scanning category user_interface
2018-02-25T07:42:05.567Z - info: Scanning into folder /data/plugins/
2018-02-25T07:42:05.569Z - info: Scanning category music_service
2018-02-25T07:42:05.570Z - info: Plugin folders cleanup completed
2018-02-25T07:42:05.576Z - info: Loading plugins from folder /volumio/app/plugins/
2018-02-25T07:42:05.591Z - info: Loading plugins from folder /data/plugins/
2018-02-25T07:42:05.598Z - info: Loading plugin "system"...
2018-02-25T07:42:05.664Z - info: Loading plugin "appearance"...
2018-02-25T07:42:07.855Z - info: Loading plugin "network"...
2018-02-25T07:42:08.005Z - info: Loading plugin "services"...
2018-02-25T07:42:08.014Z - info: Loading plugin "alsa_controller"...
2018-02-25T07:42:08.192Z - info: Loading plugin "wizard"...
2018-02-25T07:42:08.207Z - info: Loading plugin "volumio_command_line_client"...
2018-02-25T07:42:08.219Z - info: CoreCommandRouter::executeOnPlugin: alsa_controller , getConfigParam
2018-02-25T07:42:08.222Z - info: CoreCommandRouter::executeOnPlugin: alsa_controller , getConfigParam
2018-02-25T07:42:08.224Z - info: CoreCommandRouter::executeOnPlugin: alsa_controller , getConfigParam
2018-02-25T07:42:08.225Z - info: CoreCommandRouter::executeOnPlugin: alsa_controller , getConfigParam
2018-02-25T07:42:08.276Z - info: Loading plugin "upnp"...
2018-02-25T07:42:08.289Z - info: [1519544528288] Starting Upmpd Daemon
2018-02-25T07:42:08.298Z - info: CoreCommandRouter::executeOnPlugin: system , registerCallback
2018-02-25T07:42:08.304Z - info: Loading plugin "mpd"...
2018-02-25T07:42:08.610Z - info: Loading plugin "upnp_browser"...
2018-02-25T07:42:09.826Z - info: Loading plugin "networkfs"...
2018-02-25T07:42:09.870Z - info: Cannot mount NAS Musiques at system boot, trial number 1 ,retrying in 5 seconds
2018-02-25T07:42:09.872Z - info: CoreCommandRouter::executeOnPlugin: system , registerCallback
2018-02-25T07:42:09.875Z - info: Loading plugin "alarm-clock"...
2018-02-25T07:42:10.209Z - info: Loading plugin "airplay_emulation"...
2018-02-25T07:42:10.247Z - info: [1519544530246] Starting Shairport Sync
2018-02-25T07:42:10.254Z - info: Loading plugin "last_100"...
2018-02-25T07:42:10.265Z - info: Loading plugin "webradio"...
2018-02-25T07:42:10.292Z - info: Loading plugin "i2s_dacs"...
2018-02-25T07:42:10.317Z - info: CoreCommandRouter::executeOnPlugin: system , getConfigParam
2018-02-25T07:42:10.323Z - info: Loading plugin "volumiodiscovery"...
2018-02-25T07:42:10.408Z - info: Applying required configuration parameters for plugin volumiodiscovery
2018-02-25T07:42:10.481Z - info: CoreCommandRouter::executeOnPlugin: system , registerCallback
2018-02-25T07:42:10.483Z - info: Loading plugin "youtube"...
2018-02-25T07:42:13.407Z - info: Loading plugin "albumart"...
2018-02-25T07:42:13.450Z - info: Plugin example_plugin is not enabled
2018-02-25T07:42:13.452Z - info: Loading plugin "updater_comm"...
2018-02-25T07:42:14.134Z - info: Plugin mpdemulation is not enabled
2018-02-25T07:42:14.136Z - info: Loading plugin "rest_api"...
2018-02-25T07:42:14.170Z - info: Loading plugin "websocket"...
2018-02-25T07:42:14.274Z - info: ___________ START PLUGINS ___________
2018-02-25T07:42:14.283Z - info: PLUGIN START: appearance
2018-02-25T07:42:14.290Z - info: PLUGIN START: wizard
2018-02-25T07:42:14.299Z - info: PLUGIN START: upnp_browser
2018-02-25T07:42:14.306Z - info: CoreCommandRouter::executeOnPlugin: mpd , getConfigParam
2018-02-25T07:42:14.312Z - info: CoreCommandRouter::volumioAddToBrowseSources[object Object]
2018-02-25T07:42:14.318Z - info: [1519544534314] CoreMusicLibrary::Adding element Media Servers
2018-02-25T07:42:14.368Z - info: PLUGIN START: last_100
2018-02-25T07:42:14.373Z - info: CoreCommandRouter::volumioAddToBrowseSources[object Object]
2018-02-25T07:42:14.378Z - info: [1519544534374] CoreMusicLibrary::Adding element Last_100
2018-02-25T07:42:14.386Z - info: PLUGIN START: webradio
2018-02-25T07:42:14.394Z - info: CoreCommandRouter::volumioAddToBrowseSources[object Object]
2018-02-25T07:42:14.398Z - info: [1519544534394] CoreMusicLibrary::Adding element Webradio
2018-02-25T07:42:14.406Z - info: CoreCommandRouter::executeOnPlugin: system , getSystemVersion
2018-02-25T07:42:14.415Z - info: PLUGIN START: youtube
2018-02-25T07:42:14.420Z - info: Youtube::onStart Adding to browse sources
2018-02-25T07:42:14.425Z - info: CoreCommandRouter::volumioAddToBrowseSources[object Object]
2018-02-25T07:42:14.429Z - info: [1519544534425] CoreMusicLibrary::Adding element Youtube
2018-02-25T07:42:14.444Z - info: Loading i18n strings for locale fr
2018-02-25T07:42:14.529Z - info: CoreCommandRouter::executeOnPlugin: mpd , getConfigParam
2018-02-25T07:42:14.539Z - info: CoreCommandRouter::initPlayerControls
2018-02-25T07:42:14.569Z - info: CoreCommandRouter::executeOnPlugin: alsa_controller , getConfigParam
2018-02-25T07:42:14.574Z - info: CoreCommandRouter::executeOnPlugin: alsa_controller , getAlsaCards
2018-02-25T07:42:14.638Z - info: CoreCommandRouter::executeOnPlugin: alsa_controller , getConfigParam
2018-02-25T07:42:14.643Z - info: CoreCommandRouter::executeOnPlugin: alsa_controller , getConfigParam
2018-02-25T07:42:14.647Z - info: CoreCommandRouter::executeOnPlugin: alsa_controller , getConfigParam
2018-02-25T07:42:14.652Z - info: CoreCommandRouter::executeOnPlugin: alsa_controller , getConfigParam
2018-02-25T07:42:14.656Z - info: CoreCommandRouter::executeOnPlugin: alsa_controller , getConfigParam
2018-02-25T07:42:14.686Z - info: CoreCommandRouter::executeOnPlugin: mpd , getConfigParam
2018-02-25T07:42:14.697Z - info: BOOT COMPLETED
2018-02-25T07:42:14.704Z - info: CoreCommandRouter::executeOnPlugin: system , getConfigParam
2018-02-25T07:42:14.737Z - info: CoreCommandRouter::Close All Modals sent
2018-02-25T07:42:14.989Z - info: CoreStateMachine::resetVolumioState
2018-02-25T07:42:14.995Z - info: CoreStateMachine::getcurrentVolume
2018-02-25T07:42:15.000Z - info: CoreCommandRouter::volumioRetrievevolume
2018-02-25T07:42:15.041Z - info: CoreStateMachine::updateTrackBlock
2018-02-25T07:42:15.047Z - info: CorePlayQueue::getTrackBlock
2018-02-25T07:42:15.092Z - info: Cannot mount NAS Musiques at system boot, trial number 2 ,retrying in 5 seconds
2018-02-25T07:42:15.418Z - info: Setting Device type: Raspberry PI
2018-02-25T07:42:15.437Z - info: MPD running with PID585 ,establishing connection
2018-02-25T07:42:15.889Z - info: VolumeController:: Volume=undefined Mute =undefined
2018-02-25T07:42:15.901Z - info: CoreStateMachine::pushState
2018-02-25T07:42:15.909Z - info: CoreStateMachine::getState
2018-02-25T07:42:15.914Z - info: CorePlayQueue::getTrack 0
2018-02-25T07:42:15.921Z - info: CoreCommandRouter::volumioPushState
2018-02-25T07:42:15.925Z - info: CoreCommandRouter::executeOnPlugin: volumiodiscovery , saveDeviceInfo
2018-02-25T07:42:15.936Z - info: interfaceApi::pushState
2018-02-25T07:42:15.965Z - info: Volumio called home
2018-02-25T07:42:16.037Z - info: Pushing Favourites {"service":"mpd","uri":"","favourite":false}
2018-02-25T07:42:16.434Z - info: Cannot read play queue from file
2018-02-25T07:42:16.512Z - info:
2018-02-25T07:42:16.764Z - info: CoreStateMachine::setRepeat null single undefined
2018-02-25T07:42:16.766Z - info: CoreStateMachine::pushState
2018-02-25T07:42:16.768Z - info: CoreStateMachine::getState
2018-02-25T07:42:16.770Z - info: CorePlayQueue::getTrack 0
2018-02-25T07:42:16.773Z - info: CoreCommandRouter::volumioPushState
2018-02-25T07:42:16.776Z - info: CoreCommandRouter::executeOnPlugin: volumiodiscovery , saveDeviceInfo
2018-02-25T07:42:16.783Z - info: interfaceApi::pushState
2018-02-25T07:42:16.795Z - info: CoreStateMachine::setRandom null
2018-02-25T07:42:16.799Z - info: CoreStateMachine::pushState
2018-02-25T07:42:16.804Z - info: CoreStateMachine::getState
2018-02-25T07:42:16.814Z - info: CorePlayQueue::getTrack 0
2018-02-25T07:42:16.820Z - info: CoreCommandRouter::volumioPushState
2018-02-25T07:42:16.825Z - info: CoreCommandRouter::executeOnPlugin: volumiodiscovery , saveDeviceInfo
2018-02-25T07:42:16.831Z - info: interfaceApi::pushState
2018-02-25T07:42:16.949Z - info: Pushing Favourites {"service":"mpd","uri":"","favourite":false}
2018-02-25T07:42:16.958Z - info: Pushing Favourites {"service":"mpd","uri":"","favourite":false}
2018-02-25T07:42:17.863Z - info: [1519544537861] Shairport-Sync Started
2018-02-25T07:42:17.905Z - info: mDNS: Found device mpbas01
2018-02-25T07:42:20.762Z - info: Cannot mount NAS Musiques at system boot, trial number 3 ,retrying in 5 seconds
2018-02-25T07:42:20.803Z - info: CoreCommandRouter::volumioGetState
2018-02-25T07:42:20.804Z - info: CoreStateMachine::getState
2018-02-25T07:42:20.805Z - info: CorePlayQueue::getTrack 0
2018-02-25T07:42:20.881Z - info: CoreCommandRouter::Close All Modals sent
2018-02-25T07:42:21.051Z - info: Upmpdcli Daemon Started
2018-02-25T07:42:24.453Z - info: CoreCommandRouter::volumioGetState
2018-02-25T07:42:24.455Z - info: CoreStateMachine::getState
2018-02-25T07:42:24.461Z - info: CorePlayQueue::getTrack 0
2018-02-25T07:42:24.580Z - info: CoreCommandRouter::executeOnPlugin: multiroom , getMultiroom
2018-02-25T07:42:24.584Z - info: Listing playlists
2018-02-25T07:42:24.587Z - info: CoreCommandRouter::volumioGetBrowseSources
2018-02-25T07:42:24.591Z - info: CoreCommandRouter::volumioGetQueue
2018-02-25T07:42:24.593Z - info: CoreStateMachine::getQueue
2018-02-25T07:42:24.600Z - info: CorePlayQueue::getQueue
2018-02-25T07:42:25.768Z - info: Cannot mount NAS Musiques at system boot, trial number 4 ,retrying in 5 seconds
2018-02-25T07:42:30.774Z - info: Cannot mount NAS at system boot, trial number 4 ,stopping
