Hi everyone, which is the command to access to the raspi configuration ? Because raspi-config is not working.
Have a good day
I don’t know what you are trying to do, but you will need to do it manually … raspi-config is for Raspbian, not Volumio.
apt install raspi-config
is your friend
Hi, I’d try this command but it don’t work
I want to install a 5" touch screen with HDMI and USB plug, do you think I can configure this with raspi-config ?
Thanx
Mika
sudo apt install raspi-config
better to not use raspi-conf on volumio, the config.txt file must not be changed
the user settings must go into the userconfig.txt file
