I just installed volumio to my raspberry. My usb/spdif converter correctly recognized. Problem is I cannot get the fileshares from my pc to work.
Network name pc is azurisk-pc. The shared folder is on the following location H:\Music, folder is shared. No matter what I try I can’t get it to work. Any advice will be welcome. I enclosed a screenshot of current setttings.
Try the recommendations in volumio-update-t790.html
Thanks LeChuck!
Did exactly as told in the post you mentioned but still no luck. Now I get the following error when i look at nas mount I made
Last system mount error
mount error(22): Invalid argument Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
I have no clue how to fix this
*Solved
