I recently purchased the raspberry PI5 and swapped SD card from Rasp 4 to 5. It starts to boot up then stalls at this screen. Any help would be greatly appreciated.
Seems something went wrong wit the touch display plugin. Please uninstall the plugin, reboot and install again.
If this doesn’t give the desired results, reflash the SD with the latest stable version.
You are a genius! Installed touch display plugin again and it works!
Much thanks!
