Hi! On the Raspberry Pi Touchscreen the Volumio context menu is not accessible for the first items in a list, so it’s not even possible to add a folder or album to the playlist.
Thanks for reporting. Could you please open an issue here:
github.com/volumio/Volumio2-UI
I had the same issue, so I’ve rejigged the js & css files to display a minimal set of options as icons instead:
It works fine for me, as they’re the only options from the context menu that I use regularly - although I may change the eye icon (view album) into a refresh icon instead (refresh album details)
Hi Flibblebot,
what a nice little customizing of the existing UI!
I’m running my volumio with a 7“touchscreen and have the issue described above with the context menu being displayed as a dropup, overlayed by the header, regardless of the language used (english/german)
Even though it was claimed to have a fix for this in
https://forum.volumio.org/android-volumio-app-dropdown-menu-t10168.html#p60547
, it seems not to work for me.
The topic is on the Volumio2-UI issue tracker for a while now.
Is there a chance that you could share your js & css files? I would be very keen to test your setup as well.
Thanks a lot.
ctrl-c
