just did that. It says its active.
[ 38.295] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 38.295] (II) no primary bus or device found
[ 38.297] (II) LoadModule: “glx”
[ 38.307] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 38.381] (II) Module glx: vendor=“X.Org Foundation”
[ 38.381] compiled for 1.18.4, module version = 1.0.0
[ 38.381] ABI class: X.Org Server Extension, version 9.0
[ 38.381] (==) AIGLX enabled
[ 38.381] (II) LoadModule: “fbdev”
[ 38.384] (WW) Warning, couldn’t open module fbdev
[ 38.384] (II) UnloadModule: “fbdev”
[ 38.384] (II) Unloading fbdev
[ 38.384] (EE) Failed to load module “fbdev” (module does not exist, 0)
[ 38.384] (EE) No drivers available.
[ 38.384] (EE)
Fatal server error:
[ 38.384] (EE) no screens found(EE)
PRETTY_NAME=“Raspbian GNU/Linux 8 (jessie)”
NAME=“Raspbian GNU/Linux”
VERSION_ID=“8”
VERSION=“8 (jessie)”
ID=raspbian
ID_LIKE=debian
HOME_URL=…
SUPPORT_URL=…
BUG_REPORT_URL=…
VOLUMIO_BUILD_VERSION=“dd2a4339faaeb892c7f467e7dc8d424aefb0bd03”
VOLUMIO_FE_VERSION=“958dedc0edff114f244fa9acc70cf53089d9e5ae”
VOLUMIO_BE_VERSION=“307f91893fca011201acba9973e1c41bd3a0ad5d”
VOLUMIO_ARCH=“arm”
VOLUMIO_VARIANT=“volumio”
VOLUMIO_TEST=“FALSE”
VOLUMIO_BUILD_DATE=“Thu Sep 30 22:42:09 CEST 2021”
VOLUMIO_VERSION=“2.915”
VOLUMIO_HARDWARE=“pi”
VOLUMIO_HASH=“02ee61bb422c79b6e5c0b6d1847a78d9”
Please post the output of
ls -al /usr/lib/xorg/modules/drivers
ls -al /etc/X11/xorg.conf.d
ls -al /usr/share/X11/xorg.conf.d
ls -al /etc/X11
ls -al /dev/fb*
And also give
cat /var/log/Xorg.0.log
another try
One thought comes to mind: Are one or all of the .conf files you mentioned still present in your system?
If so, I guess they probably contain driver "fbdev" in Section "Device" (in accordance with post 14). Try changing the driver from “fbdev” to “fbturbo”.
I would also assume that Option "fbdev" "/dev/fb0" has to be Option "fbdev" "/dev/fb1" when using DisplayLink.
-rw-r–r-- 1 root root 956 Dec 7 2016 fbturbo_drv.la
-rw-r–r-- 1 root root 46172 Dec 7 2016 fbturbo_drv.so
-rw-r–r-- 1 root root 59956 Nov 11 2016 modesetting_drv.so
-rw-r–r-- 1 root root 316 Oct 7 20:14 95-touch_display-plugin.conf
-rw-r–r-- 1 root root 1350 Nov 11 2016 10-quirks.conf
-rw-r–r-- 1 root root 788 Sep 30 2016 40-libinput.conf
-rw-r–r-- 1 root root 2747 Oct 28 2016 70-wacom.conf
-rw-r–r-- 1 root root 607 Dec 7 2016 99-fbturbo.conf
/etc/X11
-rwxr-xr-x 1 root root 709 Sep 25 2013 Xreset
drwxr-xr-x 1 root root 4096 Oct 7 20:04 Xreset.d
drwxr-xr-x 1 root root 4096 Oct 7 20:04 Xresources
-rwxr-xr-x 1 root root 3517 Sep 25 2013 Xsession
drwxr-xr-x 1 root root 4096 Oct 7 20:04 Xsession.d
-rw-r–r-- 1 root root 265 Sep 25 2013 Xsession.options
-rw-r–r-- 1 root root 601 Oct 7 20:07 Xwrapper.config
drwxr-xr-x 2 root root 4096 Oct 7 20:04 app-defaults
drwxr-xr-x 6 root root 4096 Oct 7 20:03 fonts
lrwxrwxrwx 1 root root 14 Dec 6 2016 openbox → …/xdg/openbox
-rw-r–r-- 1 root root 17394 Sep 25 2013 rgb.txt
drwxr-xr-x 2 root root 4096 Oct 7 20:04 xinit
drwxr-xr-x 2 root root 4096 Jun 6 2014 xkb
drwxr-xr-x 2 root root 4096 Oct 7 20:14 xorg.conf.d
drwxr-xr-x 2 root root 4096 Oct 7 20:04 xsm
/dev/fb*
crw-rw---- 1 root video 29, 0 Sep 30 20:42 /dev/fb0
Ok, no “custom” .conf files.
If I didn’t misread post #14 “fb1” appears if the MIMO display is connected by USB. As only “fb0” is showing up in /dev now I guess the display was not connected by USB. (?)
Did you try my suggestion after you reinstalled the plugin?
The problem I was having was I was using fbdev instead of fbturbo.
So, to get the Mimo UM-1080CP-B USB to work I added the following:
In /boot/userconfig.txt, I added:
hdmi_group=2
hdmi_mode=28
hdmi_drive=1
hdmi_blanking=1
In /usr/share/X11/xorg.conf.d/99-fbturbo.conf, I added:
Section “Device”
Identifier “Allwinner A10/A13 FBDEV”
Driver “fbturbo”
Option “fbdev” “/dev/fb0”
Option “SwapbuffersWait” “true”
EndSection
Section "Device"
Identifier "FBDEV 1"
Driver "fbturbo "
Option “fbdev” "/dev/fb1"
EndSection
Section "Screen"
Identifier "UGA"
Device "FBDEV 1"
Monitor "Monitor name 1"
EndSection
Sorry for the trouble.
Thanks for your help. It works very well.
Glad it’s solved!
Hi Guys
Have a Raspberry Pi 4 with 8gb ram and 2 HDMI ports, and i instaled Volumio , but only One port HDMI works, Can you Help me
i will have a 7" display, and i will on another HDMI port to run Smart TV LG, but how i say, only one port on Raspberry Pi works, did i must go in Raspberry Pi set up to activate 2 HDMI or Volumio can run only one display ???
hello and welcome ![]()
I don’t know if two HDMI’s work at the same time, @gvolt do you know if this works.
but you indicate that you have a smart tv … why not open a browser on your smart tv and then go to the ip address of that raspberry pi then you also get the volumio interface.
THX a LOT , its working for now
Hi
i have raspberry pi4 b 8gb
and i have 2 hdmi , can i run 2 display at same time ???, i have on HDM O port a 7"display with resolution 1024x600 i want to rub on HDMI a TV with the same resolution or Higher , is this posible ??
i already have input config.txt
initramfs volumio.initrd
gpu_mem=32
max_usb_current=1
dtparam=audio=on
audio_pwm_mode=2
dtparam=i2c_arm=on
disable_splash=1
hdmi_force_hotplug=1
force_eeprom_read=0
disable_overscan=1
config_hdmi_boost=7
hdmi_group=2
hdmi_mode=87
hdmi_drive=1
hdmi_cvt=1024 600 60 6 0 0 0
include userconfig.txt
and in userconfig text
max_framebuffers=2
can you help me thx A LOT
