Hi, my raspberry Pi Zero 2 was no longer reachable, when I went to check it, it was extremely hot, to the point that the PCB got discoloured and the case started melting!
I’d like to check if there are any logs to help me see what might have caused the issue, but of course it no longer boots.
Is there any way I could pull the logs from the SD card before it died? Thanks!
