Couldn’t get it work properly with Volumio. My musical Fidelity M1 Dac worked out of the box with Raspyfi 1.0, but with Volumio i hear cracking sound all the time.
Is there any workaround to fix this issue?
Hi
I have exactly the same problem with my V90-Dac.
Apparently, major problems were detected.
According to the developers soon a new version is released.
Greetings
rost21A
michelangelo wrote:
Maybe (touching… ) we have the solution:
1- Connect to SSH (user root, password volumio)
2- edit /etc/modprobe.d/alsa-base.conf with
nano /etc/modprobe.d/alsa-base.conf
and add this line in the end of the file
options snd-usb-audio nrpacks=1
3- save with ctrl+x
4- reboot
5- report here how this goes. If it works, I’ll drink a long-island to you guys tonight!
And set in the WebUi resampling to 16/44.
This works for me and my M1 DAC.
Karsten
Could you please try without resampling?
sorry,
resampling is not nessessary !
Karsten
was this issue fixed?
