Hello!
I’ve just installed the latest (1.55) volumio on my raspberry pi and it seems to work to a large extent. I enabled airplay and volumio is detected as an airplay device which I can connect to, using for example my iPad (iOS 8.4.1).
When I stream from my iPad it looks like the music is playing (progress bar is moving etc) but no sound comes out of the raspberry pi.
However, if I use the program Airfoil (4.8.14) on my macbook I can stream to the raspberry pi without any problem.
Anyone who have had this problem before or have any ideas how to solve it?
Thanks in advance!
Cheers
Erik
