Im kind chasing my own tail last few days so I decide just to ask.
my setup:
Raspberry Pi 4, 4GB
Volumio 2.882-2021-04-24-pi
touchscreen GeChic 1303i (13.3 inch 1080p Touchscreen) connected via HDMI
is it possible for this version of Volumio on this version of Raspberry to work with this screen?
Steps that I did:
log via ssh
sudo apt update
from GUI install Touch Display 1.3.0 plugin
in /boot/config.txt I added flowing lines:
hdmi_group=2
hdmi_mode=87
hdmi_cvt 1920 1080 60 3 0 0 0
hdmi_drive=1
And there is no error as far as I can see, but there is also no picture on Touchscreen.
In addition when I run systemctl status -l volumio-kiosk there is following: May 20 11:16:37 volumiocotra pulseaudio[1317]: Unable to contact D-Bus: org.freedesktop.DBus.Error.Spawn.ExecFailed: /usr/bin/dbus-launch terminated abnormally without any error message May 20 11:16:37 volumiocotra pulseaudio[1317]: Unable to contact D-Bus: org.freedesktop.DBus.Error.Spawn.ExecFailed: /usr/bin/dbus-launch terminated abnormally without any error message May 20 11:16:37 volumiocotra pulseaudio[1317]: org.bluez.Manager.GetProperties() failed: org.freedesktop.DBus.Error.UnknownMethod: Method “GetProperties” with signature “” on interface “org.bluez.Manager” doesn’t exist
I do not know is this relevant for issue with touchscreen?
your screen needs usb for touch ? if you need help with your display @gvolt knows a lot of displays …
is he missing the usb line in the config? gvolt?
Ok, it was connected to HDMI 1, I connected it now to HDMI 0, but result is the same no picture
Yes just touch is connected via USB, Visual goes over HDMI. Regarding power screen is connected to 220V in wall socket. so power is not coming over usb.
But it start working once I remove: hdmi_group=2 hdmi_mode=87 hdmi_cvt 1920 1080 60 3 0 0 0 hdmi_drive=1
from /boot/config.txt that I added previously.
Tnx for you help and quick responses.
One more question. Its not in full screen. There are black margins on edges.
Is there a way/some settings so that that picture appears in full screen.
