Raspberry Pi 3B+ vs. 4B for DAC Streaming
Hey, I‘m planning on building a Spotify streamer using a raspberry pi with DAC Pro HAT.
I want to only use it as a receiver, letting me stream via spotify connect and eventually bluetooth but mainly spotify.
I came across a great package deal: RPi 3B+, DAC Pro HAT, Case, SD-Card and Power Adapter for 50 bucks.
I asked ChatGPT if the 3B+ would be sufficient and it said that the 4B would be way better as the 3 has noticable latency, especially when skipping songs. It also said that there would eventually be stops in music as the 3‘s wifi isn‘t so stable. For bluetooth, it told me the 3 would be too unreliable for smooth streaming.
I wanted to ask if anyone of you has experience with both pis and can maybe enlighten me if I should take the offer or if I should rather opt for a 4B.
Smooth streaming like on a Sonos Speaker is important to me for a smooth experience. Thanks for any advice in advance :slight_smile:
The rPi3 might become less stable and start lagging, especially with Bookworm around the corner, which demands more from the rPi3.
If you plan to use WiFi in combination with either Spotify Connect and Play music from your phone over Bluetooth, I would advice a rPi4.
Obviously, a somewhat different setup, but you may take my experidnce into consideration.
In my Pro-Ject Streambox Ultra, I tried to substitute the rpi 3 it was ‘born with’ with a rpi 4 (both computer modules).
It sort of worked (with the most recent verdion of Volumio) - at least for a while after booting the device.
Then it stopped playing when changing source…
So now the rpi 4 is just sitting waiting for another idea;-)
The Pro-Ject is designed specifically to use the rpi cm3, so it’s not too surprising, that the 4 did not work that well.
I may give it another try, a few updates down the road.
I may even try to install the Pro-Ject version of Volumio to it, although that’s rather outdated and lacks support for Tidal Connect.
Getting Tidal Connect was one of the reasons to install ‘real’ Volumio. Another was to continue getting updates - it seems like Pro-Ject have given up on that, entirely:-(
Upgrading to the rpi 4, I was hoping both for better performance (especially in the future) and to prolong the time where the hardware supported the latest version of Volumio.
So far not too successful, though.
Yeah, I tried to give Pro-Ject digital products a chance… and they ghosted me harder than my New Year’s fitness goals when asking for support and their crap product. Bought the Pre Box S2 Digital with high hopes, now it’s more like Pre Box S.O.S.
Support? Apparently that’s just a myth told by optimistic audiophiles. I regret it daily, like that time I thought I could pull off bangs.
The CM4 is more then capable running Volumio, but the HW of the streambox was not designed for it.
Running exactly that here - 3B+ with IQAudio DAC PRO. I can’t see any concerns with the performance.
Spotify, changes tracks quickly:
top - 13:01:21 up 12 days,  8:27,  1 user,  load average: 0.24, 0.07, 0.02
Tasks: 157 total,   1 running, 156 sleeping,   0 stopped,   0 zombie
%Cpu(s):  3.0 us,  0.5 sy,  0.0 ni, 96.5 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
MiB Mem :    869.8 total,    107.2 free,    251.7 used,    510.9 buff/cache
MiB Swap:      0.0 total,      0.0 free,      0.0 used.    546.4 avail Mem
  PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     TIME+ COMMAND
14516 volumio   20   0  645780  47868  15744 S  10.2   5.4  26:02.21 go-librespot
10984 volumio   20   0    8072   2816   2304 R   0.7   0.3   0:00.50 top
  382 root       0 -20       0      0      0 I   0.3   0.0   8:55.48 kworker/u13:2-brcmf_wq/mmc1:0001:1
  699 nqptp     20   0    2208   1536   1536 S   0.3   0.2  25:20.02 nqptp
  981 volumio   20   0  255024 125876  39040 S   0.3  14.1   7:48.44 node
 1217 shairpo+  20   0  176844  19328  16128 S   0.3   2.2  41:12.26 shairport-sync
10906 volumio   20   0   12396   4240   3456 S   0.3   0.5   0:00.06 sshd
    1 root      20   0   33964   8240   6476 S   0.0   0.9   0:16.89 systemd
    2 root      20   0       0      0      0 S   0.0   0.0   0:00.40 kthreadd
    3 root      20   0       0      0      0 S   0.0   0.0   0:00.00 pool_workqueue_release
Airplay2 (I upgraded shairport-sync), around 2 seconds of delay changing tracks:
top - 13:05:05 up 12 days,  8:30,  1 user,  load average: 0.07, 0.06, 0.02
Tasks: 157 total,   2 running, 155 sleeping,   0 stopped,   0 zombie
%Cpu(s):  1.1 us,  1.3 sy,  0.0 ni, 97.5 id,  0.0 wa,  0.0 hi,  0.2 si,  0.0 st
MiB Mem :    869.8 total,     94.2 free,    264.7 used,    510.9 buff/cache
MiB Swap:      0.0 total,      0.0 free,      0.0 used.    533.4 avail Mem
 1217 shairpo+  20   0  221436  23680  17536 S   7.6   2.7  41:15.89 shairport-sync
  382 root       0 -20       0      0      0 I   1.3   0.0   8:56.43 kworker/u13:2-brcmf_wq/mmc1:0001:1
  699 nqptp     20   0    2208   1536   1536 S   0.7   0.2  25:20.75 nqptp
 8681 root      20   0       0      0      0 I   0.7   0.0   0:00.78 kworker/0:0-events
10984 volumio   20   0    8072   2816   2304 R   0.7   0.3   0:02.10 top
    4 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/R-rcu_g
    5 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/R-rcu_p
    6 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/R-slub_
I might be able to lower the track change delay by tuning buffering parameters, but haven’t tried.
It is a bit less reliable as an Airplay destination for some reason - sometimes it doesn’t show, sometimes it shows but doesn’t connect, and then it finally connects. Then it just works.
HTH,
Pedro
I don understand??? You must use an adapter board to be able to use the compute module 4 on the Pro-ject s2 ultra (cm3). I have been using it for months now without issue… the volumio os works fine, the only thing is that I don’t have wirfi only ethernet connection. As a matter of fact now I am using the compute module 5 on the S2 ultra since cm4 and cm5 are backward compatible the cm5 module has a built in wireless antenna so I have wifi now.
Ahh. I mixed up things a bit…
It is the CM4S, I have tried - it uses the same SODIMM interface as the CM3.
I’m not quite aware of possible differences between CM4 and CM4S when it comes to performance??
Does adapter and CM4/5 fit into the Pro-Ject box?
The adapter cm3 to cm4 is larger so at this time I have the S2 ultra without the cover ;however I am thinking to 3d print a new cover or cut a slot on the aluminum cover. If u give it a try let me know if u hear an improvemnt in sound. I hear an improvement in sound with the CM5… do u use a linear power supply with your S2 ultra?
I believe, I’ll first see, if can get the CM4s to work properly (probably I’ll be waiting for the final release of Vol. 4).
Do you use a solid state PSU?
If so, which one?
So far, I just use the one supplied with the device.
I considered either a better one from Project or their battery.
Yes I use a linear power supply and i noticed the sound improvement when upgrading from the stock power supply. I bought a linear power supply from Aliexpress, I use my s2 ultra with use with a dual es9038 dac with Stacatto opamps and the Willsenton R8 tube amplifier.
