Raspberry Pi 3 Model B+ with hifiberry Digi+Pro and VOLUMIO
Hi All,
Hi Michelagelo
Congratulations on the Volumio project
I bought Raspberry Pi 3 Model B+ with HIFIberry Digi+ Pro .
I want use S/PDIF output to connect my DAC
After many test it doesn’t work, No Audio from S/PDIF output or RCA Connector ( Only USB from rpi…)
Looking many post I discovered that there are some problems but I don’t understud if HIFIBerry Digi+ Pro is compatible or not .
could you help me ? Any suggestion ?
This recent post has it working ok volumio-and-hifiberry-digi-pro-t9043.html , but neither of you say which version of Volumio you were using.
I’m using VOLUMIO VERSION: 2.565
Looking at the link … the version was volumio 2.362
SOLVED
It is necessary only to follow the steps :
1 Reinstall SW on SD
2 plug in the HIFIBERRY
2 Start new configuration of Volumio from scratch .
