Raspberry Pi 2B Wi-Fi
Hi
Really excited to start using Volumio to bring an old RPi back to life. However, really struggling to find solid information on WiFi dongle compatibility.
The 2B doesn’t have onboard WiFi so I’m using a known good TP-Link TL-WN823N. Wired is working really well with a USB DAC :+1:
Volumio however doesn’t seem to support the WiFi dongle.
Can I make that dongle work easily?
Is there a recommended plug n play alternative?
Any other suggestions really appreciated.
There is an archived compatibility list here:
There is also a statement that wireless adapters rarely cause problems with Volumio.
I have had many problems with usb wifi dongles. The major issue is the need for volumio to set up a hot spot , which doesn’t work with some. From memory the list of supported adapters was very short and none were available in the UK. The work around is set up Volumio with wired ethernet ( even if a dongle is plugged in wired takes precedence) you can fully set up everything including selecting wifi network and password. Then shutdown and restart with the wired ethernet removed.
I am using a Rpi 2 with a DAC HAT and an early usb wifi branded as wiPi and everthing works well with Volumio 4. During the Development of Volumio 4 the hot spot didn’t work ( so I used the work around) I sent several log files and thanks to Nerd this was fixed at some point. He might have some advice.
Thanks - when i slide the enable button on the WiFi settings it switches itself back off again before i have change to pick any SSID. It’s like it tries to start the service then fails.
Hi.
I have a RPi2B and a EDIMAX BPSCA EW-7811UN - CS25861 USB adapter; it works with no issue
Does the Pi 2 have another USB port?
Maybe try using a different port and see if the behaviour is the same.
No success with different ports.
volumio@volumio:~$ lsusb
Bus 001 Device 008: ID 2357:0109 TP-Link TL WN823N RTL8192EU
Log says “No wireless interface”
info: Listing playlists
info: CALLMETHOD: system_controller network saveWirelessNet [object Object]
info: CoreCommandRouter::executeOnPlugin: network , saveWirelessNet
 volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/chmod 777 /etc/network/interfaces
 volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/chmod 777 /etc/dhcpcd.conf
info: Permissions for /etc/network/interfaces set
info: Restarting Wireless Network
info: CoreCommandRouter::executeOnPlugin: volumiodiscovery , onNetworkingRestart
 volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/systemctl restart wireless.service
Starting Wireless Services...
WIRELESS: No wireless interface, exiting
command failed: No such device (-19)
Error for wireless request "Set Power Management" (8B2C) :
    SET failed on device wlan0 ; No such device.
wireless.service: Succeeded.
Started Wireless Services.
info: CoreCommandRouter::executeOnPlugin: wizard , reportWirelessConnection
info: CoreCommandRouter::executeOnPlugin: network , getWirelessInfo
 volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/ifconfig wlan0
info: Discovery: Networking Restart detected, restarting advertisement and browsing
info: Discovery: Restarting Advertising
info: Discovery: Stopping existing advertisement
info: Discovery: Restarting Browsing
info: Discovery: A device disappeared from network
info: CoreCommandRouter::executeOnPlugin: upnp , onRestart
info: CoreCommandRouter::executeOnPlugin: network , onNetworkingRestart
info: Refreshing Cached IP Addresses
 volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/bin/killall upmpdcli
 volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/ifconfig eth0
upmpdcli.service: Succeeded.
info: CoreCommandRouter::executeOnPlugin: my_volumio , getAutoUpdateCheckEnabled
info: CoreCommandRouter::executeOnPlugin: metavolumio , getInfinityPlayback
/bin/cat: /sys/class/net/wlan0/flags: No such file or directory
info: CoreCommandRouter::executeOnPlugin: system , getAdvancedSettingsStatus
info: CoreCommandRouter::executeOnPlugin: updater_comm , getUpdateMessageCache
info: CoreCommandRouter::executeOnPlugin: network , getInfoNetwork
 volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/ethtool eth0
 volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/iwconfig wlan0
info: CoreCommandRouter::executeOnPlugin: network , getWirelessNetworksScanCache
 volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/iwlist wlan0 scan
error: An error occurred while scanning: Error: Command failed: sudo /sbin/iwlist wlan0 scan
wlan0     Interface doesn't support scanning.
info: Cannot use regular scanning, forcing with ap-force
 volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/iw dev wlan0 scan ap-force
error: Cannot use fallback scanning method: Error: Command failed: /usr/bin/sudo /sbin/iw dev wlan0 scan ap-force
info: CoreCommandRouter::executeOnPlugin: wizard , getOnboardingWizard
Hmmm, I see quite a few people having trouble with that device. An example:
https://givinglessfucks.com/tl-wn823n/
Picked up a cheap adapter from Amazon with a Ralink chipset and worked immediately and solid so far.
Lsusb says….
Ralink Technology, Corp. MT7601U Wireless Adapter
